June 10, 20215 yr Hi, in android app I cannot read multiline fields that has more than 20 lines. There are no scrollbars and there is nothing to indicate that the text is cut, but it continues. To read everything you have to make a selection and scroll, or go into edit mode, but even there they are not very user friendly to handle. My android app version is: 6.6.7.510
June 11, 20215 yr Hey @Sm77 Thanks for reporting this issue. We have found the problem with multi-line fields and it has assigned to the team for a fix.
