June 21, 20215 yr There are some pages where autofill doesn't work. For example tumblr.com. Is there anything I can do? I use Vivaldi but it's the same with Firefox and Safari and Edge.
June 21, 20215 yr Hey @Podrageanu Sorry for the trouble. To test this issue better, please share the below details- On which device and OS are you facing this issue? Which Enpass version you using on the same? Is there any other website page where you facing this issue? Thanks!
June 21, 20215 yr Author 1. On a PC with Windows 10 with Vivaldi, Chrome an Edge; on a Mac with Big Sur with Vivaldi. Chrome and Safari 2. 6.6.3 (840), but the problem is old 3. Yes. But I have no list.
June 24, 20215 yr Hey @Podrageanu Thanks for reporting this issue. We have found the autofill problem with tumblr.com and it has shared for a fix.
