June 26, 20215 yr Can Enpass sync to a vault on a removable flash type drive? Also, could one sync using say iCloud and then remove the data from iCloud leaving the freshly synced vault on a device? Sort of a temporary or one time cloud sync. Thanks!
June 26, 20215 yr Yes on both. There's folder sync as an option. Just point out the mounted USB drive. There's also the portable version of Enpass that stores not only the vault but the application itself on a flash drive Regarding the cloud sync, there's an option when you disconnect the sync provider whether data in the cloud should be removed or not. But cloud sync isn't made as an onetime backup operation so you just have to setup sync, then wait a few seconds for the sync to cloud to complete then remove the sync again.
