July 10, 20215 yr Hello, ich have a big Problem with syc from my safes over Web Dav. Since totday I got errors wen I will syn my safes: fehlercode908403 I have disconnect it and add it new. But no Changes. the strange thing is that it doesn't happen on all of my devices Also some strange thing, since today the Apps (iOS und MacOS) often just crash completely. What can I do, to fix it?.
July 12, 20215 yr Hi @compoundbow83, Welcome to the Enpass community. If your are using Synology Diskstation for WebdDAV server then this is a known issue where the WebDAV sync is broken for Synology devices with the latest DSM and it has been notified to them for a fix. If you are having this issue, then I will recommend you wait for the update from the Synology itself. The same is also discussed in this forum -Webdav error 908403. Thank you.
