July 14, 20215 yr Hello guys, I update my passwords on a regular basis and use 2FA where it is available. The most providers of 2FA give you backup codes, i case you can't get into your account. Is there a way to store these backup codes securely? Can I just put them in the notes section? I would like to hide them as dots like the passwords. Will there be a feature like that?
July 15, 20215 yr Hi @Lukasaz1999, Thanks for reaching out to us. Yes, you can store your backup codes in a sensitive field other than note. Follow the steps mentioned below: Open Item-->Click on Edit--> Select "Add Field"-->Click on new field's label--> Chose Field Type (Multiline) and check "Sensitive" checkbox--> Save. You can now paste any multiline text in this field. I have attached a screenshot for your convenience.
