July 31, 20215 yr Randomly getting a EnpassBridge.exe - Bad Image message. Error status 0xc000012f Can't get it to open at all. Anyone else getting this error?
August 2, 20215 yr Hi @Minty, Welcome to the Enpass Community. Please update the app to the latest version v6.6.3.(836) from Microsoft Store and share your feedback. Thanks.
September 6, 20224 yr Hi, ich habe das selbe Problem mit Windows 11. Version 6.8.2 Es Funktioniert aber bei jedem Start kommt diese Fehlermeldung. Hi, i have the same problem with Windows 11. Version 6.8.2 It works but every time you start it comes up with this error message. Edited September 6, 20224 yr by RobinHood
May 15, 20233 yr Hi, I am not sure whether I will receive a response, So I have posted here in the hope that someone can offer some assistance. I have been using Enpass for some years now and this is the first time I have had to seek assistance. The Error I have is contained in the picture, It just started happening. "Windows cannot access the specified device path, or file. You may not have the appropriate permission to access the item" I have tried Uninstalling the App and Cleaning the PC and Re-installing it and verifying the Firewall settings I have also tried Garima Singh's method of deleting files from the source folder and reinstalling without any success. I have noticed that when the error occurs, attempting to Open Enpass - in Windows Event Viewer: -ErrorCode 2147942405 PackageName SinewSoftwareSystems.EnpassPasswordManager_6.86.1360.0_x86__fwdy0m65qb6h2 ContainerName SinewSoftwareSystems.EnpassPasswordManager_6.86.1360.0_x86__fwdy0m65qb6h2-S-1-5-21-3027253980-148134717-3600755693-1001 - Provider [ Name] Microsoft-Windows-AppModel-Runtime [ Guid] {f1ef270a-0d32-4352-ba52-dbab41e1d859} EventID 208 Version 0 Level 2 Task 0 Opcode 0 Keywords 0x2000000000000004 - TimeCreated [ SystemTime] 2023-05-15T10:53:52.9223554Z EventRecordID 17708 Correlation - Execution [ ProcessID] 5776 [ ThreadID] 3488 Channel Microsoft-Windows-AppModel-Runtime/Admin Computer DESKTOP-3F5S57D - Security [ UserID] S-1-5-18 - EventData PackageName SinewSoftwareSystems.EnpassPasswordManager_6.86.1360.0_x86__fwdy0m65qb6h2 ImageName EnpassBridge.exe ApplicationName SinewSoftwareSystems.EnpassPasswordManager_fwdy0m65qb6h2!App ErrorCode 2147942405 Message [LaunchProcess] Microsoft Store is functioning properly and no other Apps have problems. Your ticket ID is ECS-38364. usually within 1-2 business days? Thank You for your assistance.
May 16, 20233 yr Hi @Darrell We have received your query on support@enpass.io and have responded to the same. To avoid duplication of efforts and confusion, we request you to please revert to the same. We appreciate your understanding in this case.
July 2, 20233 yr Hi Guys It's been a while - but I finally sorted things out. I ended up doing a "System Reset" Thanks for the assistance
