August 20, 20215 yr Hi, I'm using Enpass mainly with Vivaldi on Manjaro Linux. I can't use Enpass integration in Vivaldi anymore. Whenever I request filling in a credential using right-click menu and select Enpass the small window from Enpass providing a selection of credentials shows up for a fraction of second and disappears again. Same happens when I try to establish a browser connection between Vivaldi and Enpass. This is happening since some time, so is not limited to the versions below. I already disabled all other extensions and ad blockers in Vivaldi. No improvements. I hope somebody can help... Versions: Manjaro 21.1.0 (Gnome) Vivaldi 4.1.2369.16 Enpass 6.7.0 (867)
August 23, 20215 yr Hi @thlink, Welcome to the Enpass Community. Thanks for sharing the details.I have duly noted this and forwarded it to the concerned team for further investigation. I'll let you know as soon as I have any updates on this. Thank you.
August 24, 20215 yr Hey @thlink, Can you check if you have configured your Window Manager to automatically focus the window under mouse cursor? If yes, then I would suggest to please enable dock mode for Enpass Assistant. For more information refer to this link.
August 27, 20215 yr Author Hi @Gulshan Dogra, that did the trick, thank you very much for help. I'm a happy user of Enpass again.
