August 22, 20215 yr The Bank of America website asks for a passcode at login instead of a password. Enpass does not autofill the password at this site. Could Enpass autofill the password when a passcode is requested? The problem URL is: https://secure.bankofamerica.com/login/sign-in/signOnScreen.go Thanks.
August 23, 20215 yr Hi @dcarvil, Welcome to the Enpass Community. I have forwarded this to our concerned team for further investigation. I'll let you know as soon as I have any updates for the same. Meanwhile, you can also try the Webform to save its details from the website. I would suggest you go through the user manual and let me know if that works.
August 23, 20215 yr Author I created the Webform, but the Passcode field is still not autofilled. Thanks.
August 24, 20215 yr Hi @dcarvil, I would like to share that the issue has been reproduced on our end and it will be fixed in the upcoming updates of Enpass. Thank you for reporting the issue.
