September 4, 20215 yr Hallo all, most users will have their vaults on own WebDAV servers or in a cloud of some sort. In the tutorial I miss a detailed description how to migrate the existing remotely hosted data so that the vault(s) will be distributed by the new local Wi-Fi synchronization in the future. Is the mentioned FAQ available? Thank you! Tillerbach
September 6, 20215 yr Hello @Tillerbach! Welcome to the Enpass Forum. Migrating the data from a cloud account to WiFi sync is a simple process: Disconnect the cloud sync from the devices one by one. [ If you want Enpass to remove your data from cloud, select the option "delete the data from cloud account" on your last device while disconnecting.] Setup WiFi sync as per this guide. For more information on WiFi sync, I would suggest you to visit: Detailed information on WiFi sync. WiFi sync manual setup. WiFi sync troubleshooting steps.
