October 4, 20215 yr Currently, there does not appear to be any way to duplicate an existing field in a card. When adding fields where there might be multiple instances of a field, e.g. Security Question and Answer, it would be more efficient to be able to select an existing field, choose duplicate, and then rename it, than to create each field from scratch.
October 5, 20215 yr Hi @Anthony You will be glad to know that the requested UI feature is already on our roadmap and we are currently looking into its feasibility so it may be implemented in future versions of Enpass. Appreciate your patience in the meantime!
