October 4, 20215 yr Forget the below: Solved Killed the process and restarted I have installed enpass on W10, connected successfully to G-Drive, synced all my data, confirmed the code sent to my email and could also access everything. Next time I start enpass, I get the window restore from or create account ... again. Please, how do I get rid of this? regards Chris Edited October 4, 20215 yr by ILikeMyJeep Solved
October 5, 20215 yr Hi @ILikeMyJeep, Welcome to the Enpass community. Thank you for notifying us that your issue has been resolved. I appreciate your troubleshooting skills. Sometimes the component of the system may simply get into an undefined state, rendering a malfunction but when re-set into its initial state, it may work just well afterward. Reboot basically does that it makes sure that all the computer system components are re-set into their initial state. So, in case of a non-destructive failure, the machine is rebooted and serves its purpose again
