October 28, 20215 yr Windows 10 Pro 21H1 - Enpass Desktop 6.7.2 (885) - Browser Extensions (Brave & Edge) 6.6.2 When logging in to AnonAddy the 2FA entry is left blank by Enpass, I need to manually copy and paste the 2FA code. The code is correct, but Enpass won't automatically enter the 2FA code. I have enabled both upper Autofill options including Automatically copy and fill one-time code after autofill 2FA code entry works correctly on numerous other websites, but just not AnonAddy for some reason. As a thought, where there are such issues, a feature that would help would be a 2FA button in the browser extension. So rather than having to open the entry and then copy and paste the code, you could simply click a 2FA button and Enpass would paste in the 2FA code. The browser extension has copy username, password and URL as right-click options but not 2FA. But a dedicated 2FA button would be easier and quicker. Thank you for the continued development of Enpass. Edited October 28, 20215 yr by Thoughts?
October 28, 20215 yr Hi @Thoughts?, Thank you for reaching out to us. 2 hours ago, Thoughts? said: I need to manually copy and paste the 2FA code. The code is correct, but Enpass won't automatically enter the 2FA code. I have enabled both upper Autofill options including Automatically copy and fill one-time code after autofill If you have enabled this option "Automatically copy one-time password after autofill" then Enpass will automatically copy the one-time code from the item to the clipboard, if incase it doesn't auto-fills the 2FA you just need to paste (Ctrl+V) the one-time code and log in. For more information please refer this link.
October 28, 20215 yr Author Hi Gulshan Thanks for your comment. I'm a donut for overlooking that! Is the autofill of the 2FA code at a fixed time delay, for every entry, or is Enpass analyzing the page to check when the 2FA window is shown? I wasn't sure if it was working 'blind' so to speak, or if it actually knew when the 2FA window appeared. Thanks once again.
October 28, 20215 yr @Thoughts?, Enpass runs a countdown of 30 seconds so that you know when the code expires and the new code will be automatically generated (countdown restarts). Enpass will eventually then update the one-time code. PS- Enpass will also automatically update the one-time password to the clipboard once it gets changed after 30 seconds in the item. Cheers!! Edited October 28, 20215 yr by Gulshan Dogra
