November 9, 20215 yr Could you pls add support for handling otpauth urls? For now if I set enpass as default app for that type of links - I just have got opened app, without filled up token.
November 10, 20214 yr Hello @Sundelor, I would like to share that Enpass supports 2FA for supported websites/apps. For more information, I would suggest you to visit here. For the master password, we have a keyfile feature that adds another layer of security. For more details on it visit here.
November 10, 20214 yr Author hello, @Manish Chokwal 2FA works well, and thats really great, but I'm talking about situations when site give you otpauth:// url. For now enpass desktop app doesnt know what to do with it. I'll describe the case: We've got 2fa token generator at work, it gives you otpauth:// url after sms confirmation. Default behavior that is happening in OSX - keychain app is opened and ask you to choose password item to add otp to it. (So url contains otp tocken which is autoinserted to form) What I've tried: change default url association for optauth:// from keychain to enpass, but for now enpass just opened and thats all. And it will be great, if enpass app got otpauth:// it asks for create or choose item to add otp to it, and insert token url to otp field. Hope i describe it)
November 10, 20214 yr Hello @Sundelor, Thank you for explaining the whole scenario. It would be so helpful if you can share your 2FA generator details. However, I have shared it all with the concerned team for further consideration. Your patience is highly appreciated here. #SI-2431
