file location move from document path
i have enpass 6.7.4 monterey 12.0.1 MacBook m1
the file location is under documents/enpass.
i would like to change the path. In the Enpass app under tools there is a path but this is not changeable. where can I set this?
Hi @pj2ok
Welcome to the Enpass Forums.
The option to change database location is only available for app downloaded from Enpass website. If you have downloaded Enpass from app store, it won’t be possible to change the database location. To change the database location in website version, please follow these steps:
  • Open Enpass → Under Settings, go to Advanced → Click on Change Location to change the data location.
