How to activate ?
i bought today
Please tell me how to activate it.
has it been activated?
The email address is incorrect.
I asked... to edit my email. TT
https://www.enpass.io/support/kb/registration/i-have-purchased-subscribed-enpass-how-can-i-register-and-use-the-same-license-across-devices/
If you typed your email address incorrectly when you registered it, contact support, as above. If you just want to change the registered email address follow this:
Just remove the wrong email address and register with the new one.
If you need to change the registered email address on file follow the steps in the link above to contact support and have your registered email address changed.
Hi @ironylife
I was able to find a support ticket you created and reverted on the same. To prevent duplication of efforts, please revert on the same if you have any concerns.
Thanks!
