Setting up Enpass Portable
Hello,
I am an Enpass user for several years. I am familiar with Enpass.  I have a working and stable Enpass Password Manager and a Secure Vault with 200 passwords and important notes. I need some help. I want to set up a working portable Enpass Password Manager on a USB drive. Will a stable Enpass Password Manager also work on a USB drive on the same computer or do I need a computer without Enpass installed at all?
Kind regards,
David W
Hi @Secure,
Thank you for writing to the Enpass Community Forums.
Yes, it is possible to use a stable Enpass version and a Portable version together. While using Enpass Portable version, make sure to pair it with the extension. So that extension can fetch details from the correct database.
