Feature Request: Autofill domain level blocking
Inline Autofill Popup Menu blocklist needs to allow domain blocking. so lets say I need to disable inline autofill for a site.
I can type in
http://192.168.0.1/*
instead of
http://192.168.0.1/a2b3f421_nodered/dashboard
http://192.168.0.1/core_configurator/dashboard
http://192.168.0.1/visual_code/dashboard
etc...
because the inline editor is causing issues with some sites such as node red. You can not edit with the json editor if you have inline autofill on.
Unfortunately due to the sensitive nature of the site in question I am unable to post the html
Hi @Nightangelg,
Welcome to the Enpass Community.
I have duly noted your feedback and it has been forwarded to the concerned team for further consideration.
#SI-2531
