Syncing- and editing on multiple devices
I have been using Enpass for some time-I still am not quite sure how to keep things synced- on multiple devices.  for instance if I change a password on one device- do the other devices automatically make changes as well?
Hi @gogoriviera!
How are you syncing? Normally all devices should be synced if an entry is added, changed or deleted on one device. This should be happening after starting the app and also in the background.
Hi @gogoriviera
Welcome to the Enpass Forums.
You can set up synchronization between your devices, so any changes you make on one device will also reflect on the other. Here's how you can do it -
SETTING UP SYNC –
You can set up cloud sync on your device by going to - Enpass Setting's → Vaults → Select the Vault for which you would like to set up sync → Setup Sync → Select the cloud → Continue.
RESTORING DATA -
On the welcome screen of the Enpass application on your handset, or after creating a new vault, choose to Restore Existing -> Cloud account to which you synced the details above → Enter the Vault password → Continue. All the passwords will be synced to your device. You can repeat this step on your other devices to restore your data.
Hope this helps!
