January 20, 20224 yr Adding a second existing vault to Enpass from the cloud is a pain, especially on mobile devices. One has to insert the cloud credentials, the cloud url, and the vault password. However, I normally have all this info in one item of my primary enpass vault. I envision a feature where I can select an item within enpass and setup a second vault from this item. Process: Settings > Vault > New > From existing item > Match elements of items, select cloud provider > Finished This would also simplify the process of sharing a vault with someone else: Create a pre-shared key and send via secure channel Send encrypted enpass item containing cloud credentials and vault password Import enpass item and decrypt with pre-shared key (only insert one password) Select item and setup vault from cloud sync I am looking forward to your reply. Regards, Rafa Edited January 20, 20224 yr by Rafa
January 21, 20224 yr Hi @Rafa, Welcome to the Enpass community. 17 hours ago, Rafa said: I envision a feature where I can select an item within enpass and setup a second vault from this item. Process: Settings > Vault > New > From existing item > Match elements of items, select cloud provider > Finished I appreciate you taking the time to explore our app and submit this feature request. Your suggestion has been noted and forwarded to the concerned team for further consideration/feasibility. #SI-2587
