Auto-dispose (or more controls) of backups
Hi there,
I would like Enpass to allow more controls on automatic backups.
Currently, Enpass allows automatic backups (or simply disable them and create them manually). That's fine, but I'd like to see more controls to customize backups.
For example, limiting the times to create backups in a day, or from which change a backup should be made, or how many backups should be logged or even an option to auto-delete backups according to Its age.
A considerable number of backup copies are stored on the PC, which can weigh up to more than 600 MB (with a database of 6 MB or less).
Thanks.
Hi @gabeweb
Thanks for the suggestion.
I have taken note of your request and have shared this as a feedback with our dedicated development team so they may consider this for the future versions of Enpass. Your patience is highly appreciated!
#SI-2663
