March 31, 20224 yr Hello, I would like to know if Enpass automatically deletes the passwords copied in Enpass, if windows 11 and Android keep them memorized it would not be very safe, thanks.
March 31, 20224 yr 25 minutes ago, Maurizio1313 said: Hello, I would like to know if Enpass automatically deletes the passwords copied in Enpass, if windows 11 and Android keep them memorized it would not be very safe, thanks. https://www.enpass.io/docs/manual-desktop/security.html#clear-clipboard
April 1, 20224 yr Hi @Maurizio1313 As suggested by @Ivarson, you can change the time after which the passwords copied to the clipboard get cleared by going to Enpass Desktop Settings -> Security -> clipboard -> Clear content after 'X' seconds.
