May 3, 20224 yr Using the new 6.8 for Android, I have 0 identical passwords in the audit section. If I create two new items with the same passwords (asdfgh), they appear in the "Leaked" section which makes sense, but they're not showing up as Identical.
May 4, 20224 yr Hi @Ivarson To get the concern you are facing investigated, could you please also share the Android version you are using? Awaiting your response
May 4, 20224 yr Author 2 hours ago, Abhishek Dewan said: Hi @Ivarson To get the concern you are facing investigated, could you please also share the Android version you are using? Awaiting your response Android 11, OnePlus 7T
May 5, 20224 yr Hi @Ivarson Thank you for the details. I have forwarded your concern to our dedicated testing team and will be sure to update you regarding any updates in this matter. Your patience in the meantime is appreciated. SI-2788
May 5, 20224 yr Hi @Ivarson The bug that caused this issue has been reproduced on our end, and our dedicated team is now working on fixing it. This issue will be addressed shortly with a patch. We appreciate your patience while we work on the fix.
