May 3, 20224 yr 1. When launching Enpass 6.8, The upper right vault icon reverts to the one representing the Primary vault even when All vaults are selected. If you tap it and again select "All vaults" the icon gets the correct 'ring" 2. Even if a user clears all "Leaked passwords" by creating audit exceptions for them the audit-button in the navigation bar still has a red dot. Also the red banner on top is still there
May 4, 20224 yr Hi @Ivarson, I will forward this issue to the concerned team for further investigation if you can let me know the OS version of your Android device.
May 4, 20224 yr Author 3 hours ago, Gulshan Dogra said: Hi @Ivarson, I will forward this issue to the concerned team for further investigation if you can let me know the OS version of your Android device. Android 11. OnePlus 7T
May 4, 20224 yr @Ivarson, Thank you for providing this information. This has been forwarded to our concerned team for further investigation. Any updates will be conveyed to you as soon as they are received. Thank you for your support and patience in the interim. #SI-2780
August 18, 20224 yr @Ivarson, The compromised alert popup issue has been reproduced on our end, and our team is working to resolve it. There will be an update to Enpass in the near future that will fix this issue. For the issue related to icon please provide some information. Which vault is selected in “always open to”. Are you facing this problem in on each fresh launch the app or only after update the app? #2780
August 19, 20224 yr Author On 8/18/2022 at 7:22 AM, Gulshan Dogra said: @Ivarson, The compromised alert popup issue has been reproduced on our end, and our team is working to resolve it. There will be an update to Enpass in the near future that will fix this issue. For the issue related to icon please provide some information. Which vault is selected in “always open to”. Are you facing this problem in on each fresh launch the app or only after update the app? #2780 1. Always open to: All vaults 2. Facing problem during fresh launch off app (the icon is incorrect before the sync starts or completes, and continues to be wrong after, until one re-selects All vaults). However it's not happening every time and I don't know how to reproduce it
August 22, 20224 yr @Ivarson Thank you for sharing the requested details, it has been relayed to our backend team for further investigation. #SI-2780
