May 6, 20224 yr Hi, since version 6.8 it is not longer possible to restore multiple vaults from the same webdav server. I receive the message that the same account is already connected. But it is not the same account. It is just the same URL to the webdav server. The account has a different username and password. Until version 6.7.4 it was possible to connect to multiple vaults fron the same server. It seems that this version just checks if the server address is already used and not if this is a different account. In 6.7.4 I sync about 8 vaults from the same server
May 9, 20224 yr Hi @lalelunet, Welcome to the Enpass Community Forums. Thank you for reporting the presence of this issue in v6.8. In order to investigate it better, please let me know if you are using the Enpass store version or website. Also, help me with the OS information.
May 9, 20224 yr Author Hy Manish, I test both versions. Store and download version have the same behavior. I install 6.7.4 and install all vaults. After that the version 6.8 did not start with the data base anymore Macbook pro 14" max amd Macos version 12.3.1
May 10, 20224 yr Hi @lalelunet, Thank you for reporting the presence of a database detection issue in v6.8. I suspect it could be a permissions issue. Try on your Mac, choose the Apple menu -> System Preferences -> Click Security & Privacy -> Click Privacy -> Select Files and Folders -> Select the checkbox below an app to allow it to access files and folders in that location or you can add Enpass manually if needed. You may need to click the lock icon and authenticate before you can add or change any items listed there. Let me know if that helps.
May 22, 20224 yr I, too, cannot recover data from my WebDAV server on a newly installed copy of the program. I restored from a backup, but I can not connect the synchronization. Writes about an incorrect login / password, although the file manager connects to the server with the same credentials without any problems. OS - Ubuntu 22.04. One gets the impression that starting from some copy, the program stops working normally. But where then can you delete information about registered but unused copies of the program? I often reinstall the OS. And I don't have one computer. What is the maximum number of registrations before the program fails? This information does not exist. Please help.
May 24, 20224 yr Hi @Сергей Сидоренко, Welcome to the Enpass Community Forums. Thank you for reporting the presence of this issue. Recently, we have rolled out a new Enpass version 6.8.1 for Linux. Please confirm if you are using the same Enpass version. Further, please share a demo account along with its username and password as well as its URL to allow us to investigate it better. For security reasons, please share the details in a personal message or on support@enpass.io.
July 28, 20224 yr Any news on this? I can confirm that 6.7.4.933 is the last working release on Linux platform. I have 4 vaults connected to the same webdav share mapped to the users home folder, so the path on the server is different for each vault. It seems that the introduction of Enpass-Business in V6.8 has brought some incompatible changes. In 6.8 I can only sync one vault to the webdav share. I get the above mentioned error if I try to restore a second vault. If this is a feature rather than a bug, the possibility to sync multiple vaults to the same sync share is severely hampered. I don't want to sign up to 4 different cloud providers just for Enpass. I sincerely hope there is a solution for this issue. Edited July 28, 20224 yr by Alexander Pohl
July 31, 20224 yr I am seeing the same issue. I have multiple WebDAV vaults that have worked successfully for 2+ years. I am a premium user and can connect to them from my Windows 10 machine using Enpass 6.8.2 (1084), on my iPhoneX using Enpass 6.8.1 (633), but on my new MacBook (Apple M1 Pro) running macOS Monterey 12.3 I cannot add them all. The MacBook is running Enpass 6.8.2 (1082) from the Mac App Store. On the Mac I was able to get a second WebDav vault to work, but could not add anymore after I added the second one. Note a week prior it would not let me add the second folder with the same error I am getting now "No two vaults can be connected to same account for syncing data. Connected Vault: Family All"
August 2, 20224 yr Hi @all, Thank you for being patient with us. Our team was able to reproduce this issue and working on fixing it. Its fix can be seen in future updates. In the meantime, your patience and cooperation are highly appreciated here. SI-2826
