May 23, 20224 yr Hi @ng4ever Syncing across Enpass is completely secure as all your data is transmitted in an encrypted format, and cryptography is always performed locally on the device itself. Your cloud always contains a copy of the same encrypted data as on your device. We download the whole encrypted copy and decrypt it locally on your device for real sync operation to merge changes. Afterwards, we upload the encrypted data to the cloud. In a nutshell, your cloud is only a storage medium, and no security-related operation ( encryption or decryption ) is actually performed there. All such operations are performed locally on your device. Your data is never stored or relayed through our servers. Alternatively, if you are using Enpass on a desktop, you can set cloudless sync via Wifi. Hope this helps!
