May 20, 20224 yr Hello, I have purchased your program when I saw that it was compatible on Mac for versions 10.12 and later, as it appears on your website, I have 10.13.6 When I download the application, I find that the APP does not install for me, as my computer is incompatible with it, since an operating system version of 10.14 or later would be required. Can you send me a version that is compatible with my computer (OS 10.13.6)? Juan Carlos
May 24, 20224 yr Hi @EA1AHA, Welcome to the Enpass Community Forums. Thank you for letting us know about your concern. I am sharing with you a link to download Enpass 6.7 which is compatible with your macOS 10.13.6. You can download it from here. Let me know if that works fine.
