Enpass folder under "My documents" - how to move (or delete?)
Thank you for reaching out to us.
I would like to share that Windows Store apps can access data only from their sandboxed container and it's not possible to change the default location.
NOTE: With the latest Enpass version Enpass data location can't be set on remote location. If you want to store the data location on remote location and then we recommend to use Enpass portable. Refer to this link.
