June 13, 20224 yr A couple of weeks I had to confirm a dialogue on android that enpass may display stuff in front of other apps - then this weird button (photos) with the enpass logo appeared and I have no clue where I can turn it off. It seems kinda useless, does nothing, not even on a Website with a form to fill. It can either float in the middle of the screen, can be docked to the left or right side of the screen and can also be minimized by swiping to the corresponding side. Does anybody know, how this element is called and where you can turn it of in the enpass / android settings? Thanks!
June 14, 20224 yr Hi @BleenPaper, Thank you for reaching out to us. I would like to share that this is not an Enpass feature of any kind. Disable your autofill services and check if the issue persists. Please refer to this link link for more information.
June 14, 20224 yr Author Thank you for the tip, I didn't thought of this possibility and would not have found a solution without it. It was not a bubble that could be deactivated in the apps menu but an option in "Accessibility > Installed Apps > Enpass" where you have to turn off the "Enpass Shortcut".
