June 13, 20224 yr The last search is always retained in the searchbox, even after quitting Enpass. I have "Clear Content After 30 seconds" checked. This means after opening one has to click on the 'x' to clear it. I habitually use Ctrl+f to enter a term - which is then not found, as the previous (old) term is still sitting there messing things up. How to make it auto-clear, please? Also: Enpass auto-locks a few seconds after losing focus, even though I've set: Autolock When Main Window is closed; System Sleeps; System inactive for 10 minutes. And: I only want /two/ columns, not three. How can I get rid of the 1st column, currently containing "All items (999)" and "Favourites"? Or at least, drag it to make it much smaller? Edited June 13, 20224 yr by wCorp
June 14, 20224 yr Hi @wCorp, Welcome to the Enpass Community Forum. Thank you for sharing the presence of these issues. In order to assist you better, please help me with the following details: Share the details of the Enpass version and OS information. Did you install it from a store or our website?
June 15, 20224 yr Author Hi, thanks for answering. Apologies for not providing sysinfo, I should know better than that. Moving too fast! System: Linux 5.15.5-200.fc35.x86_64 GNU/Linux (Fedora 35) Enpass v.6.8.0 (1059), installed via dnf
June 16, 20224 yr Hi @wCorp, I appreciate your response. I can see you are using an older version of Enpass. We have already released Enpass version 6.8.1 for Linux OS. Please try that and let us know if that works fine.
June 18, 20224 yr Author Hi, Upgrade to 6.8.1 installed. The auto-locking issue is resolved But: Search box still retained last search, after being closed and re-opened. And: No option to minimise/drag left-hand column; but it is smaller which is an improvement.
