June 15, 20224 yr How may I use Enpass Business AND Enpass Personal together? I do not find an option how to do that. Thanks for your help!
June 16, 20224 yr Hi @SecurepointIsAwesome It is possible to use Enpass personal and Business vaults together. To add your Personal Vault in your Enpass business version, please select Add Personal Vault under Enpass Settings -> Vaults.
June 22, 20224 yr Author On 6/16/2022 at 1:01 PM, Abhishek Dewan said: Hi @SecurepointIsAwesome It is possible to use Enpass personal and Business vaults together. To add your Personal Vault in your Enpass business version, please select Add Personal Vault under Enpass Settings -> Vaults. Thanks for the instruction. I am using the personal Enpass version and do not see the two buttons you mentioned. Where may I add my business vault?
June 23, 20224 yr Hi @SecurepointIsAwesome Since you mentioned that you are using the personal Enpass version, you will need to first activate the Enpass Business version on the welcome screen of the Enpass app - Once you have successfully activated Enpass for your Business, please refer to the steps I shared in my previous post to add your personal vault. You can also refer to this link for our handy guide on setting up Enpass for your Business.
