June 24, 20224 yr Hello, as the description says, after the latest update, since a couple of days ago, in the Enpass Assistant window (the window that opens), I could search for a password item, and press cmd-c to copy the password, but this no longer works, I have to click on the copy button.
June 24, 20224 yr This is likely related to an already reported issue. For those who have this problem, press the keyboard shortcut 3 times and it should be copied. The devs have said they are working on a fix. Edited June 24, 20224 yr by Discordant
June 28, 20224 yr Author Thank you for the reply discordant, but the work-around with the keyboard shortcut 3 times does not work. Will wait for a fix. Do you have a pointer to the initially reported issue ?
June 29, 20224 yr Hi @adragomir & @Discordant, In the new update, the existing shortcuts have been changed. Now, Cmd+Shift+P is the shortcut key to copy the passwords. For more details on Enpass Safari Shortcuts, visit the user manual.
