June 27, 20224 yr Hi! I'm always trying to use enpass browser extension to autofill my online banking login however they are asking for my number and a PIN but enpass always picks the number and my passwort. Is there any way I can tell Enpass which item to pick from my Login to autofill a certain field ? Edited June 27, 20224 yr by KarlKaos
June 28, 20224 yr Hi @KarlKaos Welcome to the Enpass Forums. For troubleshooting purposes, please refer to the steps in this link and save the Item of your Online banking app as a web form. Then try autofilling again and share your findings with me. If the issue persists, we will need additional information on this matter. Kindly share the below details with me, and I'll have this checked for you - The version of the Enpass app, OS, Enpass Extension and browser you are using. The URL of the webpage on which you are facing this issue.
June 29, 20224 yr Author Hi @Abhishek Dewan I'm using the Enpass app on macOS 12.4 the version of enpass is 6.7.4 (949) and the extension for Chrome. Here is the web page of my bank https://www.sparkasse-neuss.de/de/home.html It requires an "Anmeldenamen" and a "PIN" . But Enpass always autofills the items "Anmeldename" and "Password". In other Password Managers like bitwarden you can actually grab the field name from the html and make sure it autofills in the correct spots. Edited July 5, 20224 yr by KarlKaos
July 6, 20224 yr Hi @KarlKaos It seems that you are using an older version of Enpass. Please update your Enpass app to the latest version 6.8.2, and share your findings with me. If the issue persists, for a thorough investigation of this issue, kindly share the version of the Enpass Extension and the version of the Chrome browser as well.
July 6, 20224 yr Author Hi @Abhishek Dewan It seems the version in the Apple App store doesn't install the current version 6.8.2 like promised, but the direct link for the webbrowser worked. I'm now on version 6.8.2 (1081) and the version 6.8.0 in chrome. The Autofill still doesn't work for my online banking log in. Edited July 6, 20224 yr by KarlKaos
July 7, 20224 yr Hi @KarlKaos We tested the website which you mentioned and found that Enpass always autofill Username & Pin data on the login page. For troubleshooting purposes, please try the below steps once - Take a note of your credentials for this webpage and then create a new login Item using autosave functionality. You can also refer to this link. If the issue persists, try using the PIN data in the password field. #SI-2974
July 7, 20224 yr Author Hi @Abhishek Dewan I deleted the login item in my Enpass vault and transfered it to a notepad before. For some reason the there was no pop-up to add a new login after typing in my credentials, so I created a new login item myself and filled the PIN in the password field and renamed it afterwards. Now it works. Thank you very much.
