July 21, 20224 yr I recently switched from a Huawei Mate 20 pro to a Samsung Galaxy S22+ with Android 12 and since then, can't get the autofill to work correctly., Only with password fields, the Autofill prompt appears, but not within username fields. I have enabled "autofill with accessability" I'm using Enpass 6.8.2.666 Android 12 latest updates installed as of today. Is this a known bug or what am I doing wrong?
July 21, 20224 yr Author It seems, that in some apps, the autofill prompt on username/email does work and in some other is doesn't So far I can't get the autofill to prompt at the username/E-Mail address field in LINKEDIN , FACEBOOK. It IS working on XING, TWITTER though.
July 22, 20224 yr Hi @ralphi Welcome tot he Enpass Forums. For troubleshooting purposes, please disable and then re-enable Android Autofill Framework (Service), Autofill using Accessibility and Autofill using Enpass Keyboard in your Enpass Android app → Settings → Autofill. Let me know if the issue persists.
July 28, 20224 yr Make sure you're logged into Enpass on the server device as well as your mobile device. Make sure Enpass permissions are set to "appear on top", allow "run at startup" and "view network connectons" then restart the Enpass autofill service, restart your mobile device, log into Enpass. Verify Enpass is synchronizing correctly. Edited July 28, 20224 yr by FR8TDOG
September 29, 20224 yr Methods to fix- Method 1 – Delete Login Data and Login Data-journal. Method 2 – De-Sync and Re-Sync again. Method 3: By Updating Chrome. Method 4: Enable Autofill Settings. Method 5: Rename Default Folder. Method 6: Enable your Sync Settings. Method 7: By Turning Off Extensions. Method 8: Clear Browsing Data. This may help you, Rachel Gomez
October 3, 20224 yr Not possible to autocomplete various applications after Android 13 update. It works fine on Android 12 or lower. Browsers normally works fine for all Android versions. Las try done on Enpass version: 6.8.3.726.
October 4, 20224 yr Hi @alxamejua Welcome to the Enpass Forums. Could you please share the name of a few applications on which the autofill is not working for you? Moreover, are you unable to autofill on your Android 13 device via Enpass Keyboard?
October 5, 20224 yr Hi @Abhishek Dewan, I have developed an Android app to verify it on Android 13 and I can confirm is an issue of other applications. Enpass is working correctly. Thanks for the feedback.
