March 19, 20188 yr Hi, I'm using Enpass on a Windows 7 Environment. Enpass Version 5.6.5 Firefox Version 59.0.1 (64 bit) Plugin Version 5.5.2 Autofill works in Firefox, but I have to wait about 20 seconds until the username and password gets filled in. It doesn't make a difference whether I use the plugin icon or the context menu. After the element is chosen nothing happens for about 20 seconds. Then the credentials get autofilled. Is this a known issue? I didn't find any forum topic for this... Best regards, Ruppel Edited March 19, 20188 yr by Ruppel
March 20, 20188 yr Hi @Ruppel Thanks for bringing this to our notice. I've forwarded this issue to the testing team to look into it. Meanwhile please let me know are you facing this problem with a specific website or on all of them. Thanks!
March 20, 20188 yr Author Hi, thanks for the reply. I'm facing the issue on all websites. In our company intranet as well as in the internet (e.g. pixabay.com). Over 20 seconds nothing happens and then the credentials get entered and the login works. Thanks a lot!
March 22, 20188 yr Hi @Ruppel, Thanks for writing back and sharing the details. We've tested this issue in our lab with different websites and the URL that you mentioned but things seem to work fine here. However, we'll keep looking into it and will update you when we find something conclusive. Thanks for your co-operation.
June 6, 20188 yr Author Hi, now I have an idea, why enpass is slow on my side It's a company owned laptop and we sync the personal folders to the server. By standard enpass saves the password file inside this personal folder. And it seems that this slows down the ui. I changed the place to save the the wallet in the extended settings to a local folder and reaction time is much much better! Thanks for helping me and for the really good and nice application!
January 4, 20197 yr I'm having the same issue. I'm syncing with dropbox, and I wonder if that's related. I notice if I open the enpass app and manually sync dropbox, then the firefox autofill dialog shows up immediately. After a while of dropbox not being synced, the autofill dialog takes 15 - 20 seconds to be visible.
January 9, 20197 yr Same here since update to Enpass 6. Firefox 64 on MacOS Mojave Enpass Extension 6.0.0 Enpass 6.0.2 syncing with WebDAV When clicking on the extension icon in Firefox I have to wait for about 20 seconds. Alternatively, I can click twice. Then the popup appears immediately.
January 16, 20197 yr Hello to the Forum I have the exact same problem as @pike said in the previous message. Can you please take a look on that? Thank you
January 17, 20197 yr Hey guys, Sorry for the inconvenience. This issue has been fixed and the update will be available soon. Till then please co-operate with us.
January 17, 20197 yr 9 minutes ago, Anshu kumar said: Hey guys, Sorry for the inconvenience. This issue has been fixed and the update will be available soon. Till then please co-operate with us. Thank you very much for the reply! Keep up the good work!
January 24, 20197 yr can we get a time estimate on when it will be available? Makes it pretty much unusable for firefox.
January 24, 20197 yr Hey @rburgst, We have just pushed an update so please check and share your findings. Thanks!
