August 31, 20224 yr Hi there since I few days, I cannot edit or add entries in my Desktop Enpass. I click the EDIT Entry or the + Button but nothing happens. Restarting didnt help. What am I a doing wrong? I am running the latest version I think, at least automatic updates are enabled. I have a Premium License. Thanks Andreas Edited August 31, 20224 yr by Andreas2
August 31, 20224 yr Hey @Andreas2, Thank you for reporting this issue. Please let me know if you are trying to edit or add an item in smaller window size. If yes, try to maximize the size of the Enpass app, and let me know if that helps. Also, we are already aware of this smaller window size issue and its fix can be seen in future updates. In the meantime, your patience is highly appreciated here. SI-2967
August 31, 20224 yr Author 1 hour ago, Manish Chokwal said: Hey @Andreas2, Thank you for reporting this issue. Please let me know if you are trying to edit or add an item in smaller window size. If yes, try to maximize the size of the Enpass app, and let me know if that helps. Also, we are already aware of this smaller window size issue and its fix can be seen in future updates. In the meantime, your patience is highly appreciated here. SI-2967 Thank you Manish, if I maximize the Windows it really works. Interesting bug! Please fix this but for now the workaround of course is good THanks Andreas
