September 5, 20224 yr Hi @ng4ever As Enpass is an offline password manager, all your data is stored locally on your device. You can absolutely use Enpass on just your mobile device without ever connecting it with any other devices.
September 5, 20224 yr Author 6 hours ago, Abhishek Dewan said: Hi @ng4ever As Enpass is an offline password manager, all your data is stored locally on your device. You can absolutely use Enpass on just your mobile device without ever connecting it with any other devices. Would it be easy just having it on a mobile device or difficult ?
September 5, 20224 yr 22 minutes ago, ng4ever said: Would it be easy just having it on a mobile device or difficult ? If you only need the passwords on your phone, there's no point involving another pc or phone. You install Enpass where ever you need it?
September 6, 20224 yr Hi @ng4ever Using Enpass totally depends on the users requirements. As per your needs, you can install Enpass on just your mobile or multiple devices.
September 7, 20224 yr Author 14 hours ago, Abhishek Dewan said: Hi @ng4ever Using Enpass totally depends on the users requirements. As per your needs, you can install Enpass on just your mobile or multiple devices. Ok thanks but is it easy to add a new login with just having Enpass installed on a Android or iOS phone lets say ?
September 7, 20224 yr Hi @ng4ever Adding Items to Enpass is easy on all the ecosystems but can vary a little depending on the OS. Please refer to this link for our handy guide to know more about it.
September 7, 20224 yr 9 hours ago, ng4ever said: Ok thanks but is it easy to add a new login with just having Enpass installed on a Android or iOS phone lets say ? Not as convenient as autofill from desktop browser extensions
