September 28, 20224 yr When I'm tagging one or multiple entries and I Add Tags there isn't a pulldown list with auto search, IE as type the tag name the list of available tags is limited to those that start with what I enter.
September 29, 20224 yr Hi @DennisT, Thank you for reaching out to us. I appreciate your efforts for taking time to provide your valuable feedback. I have duly noted your suggestion and it has been forwarded to our backend team for further consideration and feasibility.
November 28, 20223 yr Hi, I second this request. Specifically: Android mobile app: need a tag picker. Currently, users have to type in an exact tag. If you misspell, a duplicate tag gets created. I usually forget exactly what I called a tag (e.g. did I call it "Design & Development" or "Development & Design"?) Windows app: need a tag picker. Currently, there is an auto-suggest as you type, but it would be easier to just select from a list of existing tags (and ability to type a few characters to narrow that list)
