October 3, 20224 yr I have a vault set up on a private cloud share folder. How can I set up enpass to automatically enter a login/password for that connection?
October 3, 20224 yr Author I have a private cloud server. On that server I have a share set up The share requires a login/password to connect to it. In Windows 10 I access the share using the login/password using File Explorer In enpass I set up my vault to use that share. Enpass syncs. reboot Enpass cannot sync to the vault. In Windows 10 I access the share using the login/password using File Explorer Then Enpass can sync. How do I get enpass to log onto the vault connection?
October 3, 20224 yr OK. You mean a smb/cifs share (not webdav). You probably need to add that file share as a network drive first, and make sure to tick "remember credentials"
October 3, 20224 yr Author In most cases access is via a VPN and the VPN isn't always in use. Windows can be quite stupid when an application cannot access a drive which would be the case most of the time. No way for Enpass to store and use the credentials and not go down the mounted drive path?
October 3, 20224 yr No, it's just a basic "folder sync" AFAIK. Yes network drives over vpns in user-context can be tricky. Windows tries to mount the drive during login and if the VPN isn't up the drive will be disconnected, most file level operation outside the shell Explorer will fail. You could look at Offline Files perhaps, but then you probably need an active directory with proper domain account and kerberos (don't know if you're using ntlmv2 on a workgroup server or just using a different account for share access). If you're using this on a personal computer, there's probably easier solutions, like cloud sync, some simple webdav-server at home or Syncthing Edited October 4, 20224 yr by Ivarson
February 16, 20233 yr To add to Enpass a cloud-synced vault being shared with you: Go to Settings, select Vaults, and click Add new vault. Select the cloud service where the shared vault is stored, which will open a special page on that cloud's website for granting access to Enpass.
