October 4, 20224 yr Hi Been using Enpass for years, great app! Android v. 6.8.3.726 I have been using Dropbox to sync my primary vault (the only one I have) I am now changing to my Nextcloud (I used to use it with no problems, but it was down for a while so I switched temporarily to Dropbox) I have done this using the correct WebDav address on my Archlabs based linux laptop - no problem ( I didnt even need to bypass SSL certificate verification, I copied the webdav address from my Nextcloud settings) Laptop Enpass version: 6.8.1 (1063) Now I am unable to do the same on my android phone I have tried fist disconnecting Dropbox (with the aim of then making a Nextcloud connection) - Then although it does say 'sync not enabled for this vault' there is also a never ending circular progress thingy and if I return to previous screen Dropbox is still linked I have also tried changing directly via the Dropdown box and selecting Nextcloud, entering the same URL as worked for my lappy, granting access in Firefox, and also I tried Chrome, with and without bypassing SSL certificate verification - but in ALL these cases I get an, 'Error Something went wrong while syncing' and then I am back to the never ending circular progress thingy and if I return to previous screen Dropbox is still linked I have also tried via the WebDav option in the dropdown box and the same thing happens I am out of ideas LOL Can anyone suggest anything, please? TIA Edited October 4, 20224 yr by Bobsyouruncle included linux Enpass version
October 4, 20224 yr Hi @Bobsyouruncle, Welcome to the Enpass community. Our sincere thanks go out to you for letting us know that the issue has been resolved.
October 4, 20224 yr Author Hi @Gulshan Dogra Thanks But its not really resolved - there is still something wrong with the app
October 7, 20224 yr @Bobsyouruncle, Can you please share the screenshot of the error you are facing while connecting with your respective cloud, so that I can get this issue investigated by our concerned team.
March 26, 20233 yr On 10/4/2022 at 1:39 PM, Bobsyouruncle said: Workaround: Uninstalled then reinstalled Enpass from Android I have Enpass Android with WebDAV sync. When changing sync server password, the ONLY fix to get sync back was to uninstall and reinstall. All other platforms (macOS, Windows, iOS) worked without problems. Apparently any change on sync cannot be compensated with vault settings.
