October 7, 20224 yr Hi, I unknowingly moved an Enpass folder on my HD and I was forced to re-add my vaults the next time I launched Enpass. After re-adding my vaults, the keyboard shortcuts for copying Username, PW and OTP in the helper are not working anymore. I still get the little popup text that says "Copied to Clipboard", but nothing is copied. Anyone have similar experience?
October 8, 20224 yr Author 14 hours ago, Discordant said: What version of Enpass are you running? 6.8.3 (1150)
October 10, 20224 yr Hey @dn_chris, I appreciate your efforts in sharing the presence of this issue. In order to assist you better, please help me with the following details: Share the macOS version. Additionally, check if the clipboard timing is enough in the Enpass Security settings.
October 11, 20224 yr Author 20 hours ago, Manish Chokwal said: Hey @dn_chris, I appreciate your efforts in sharing the presence of this issue. In order to assist you better, please help me with the following details: Share the macOS version. Additionally, check if the clipboard timing is enough in the Enpass Security settings. 1. macOS Monterey 12.6 2. I set the clipboard so that it never clears Thanks,
October 12, 20224 yr Hey @dn_chris, I appreciate your response. I have shared it with the concerned team for further investigation. In the meantime, your patience is highly appreciated here. SI-3135
October 12, 20224 yr Author 3 hours ago, Manish Chokwal said: Hey @dn_chris, I appreciate your response. I have shared it with the concerned team for further investigation. In the meantime, your patience is highly appreciated here. SI-3135 Looking forward to your update.
October 13, 20224 yr Hey @dn_chris, I appreciate you for being patient with us. Our team was able to reproduce this issue and working on fixing it. Its fix can be seen in future updates. In the meantime you can try this workaround, you can copy the respective fields by opening the item in details mode in Extension using the “i”(Information) button to the right of the selected item for the website.
