November 5, 20224 yr Dear Enpass Developers, I have a question about Enpass and seeds for two-factor authentication (e.g. OTP). Is it possible to easily export seeds for two-factor authentication FROM Enpass? Thanks M
November 8, 20223 yr Hi @MMyth Welcome to the Enpass Forums. When you export your Enpass data, any Item to which you have added the Secret Key/Seed is automatically exported. The key/seed is visible when the file format is .txt or .csv. You can export your Enpass data by going to Enpass Menu (Hamburger Icon) -> File -> Export.
