Default Section(s) removal not reflected after edit
If you edit and remove default sections they are still showing after save.  They are correctly removed from the MacOS app.  It also works correctly if you are creating your own custom sections.  I am not sure if this is a known issue?  I included screen shot example of the issue.
Edited by NasaRacer
grammer error
Hi @NasaRacer
For troubleshooting purposes, please follow the below steps -
  1. Ensure that you have installed the latest version of the Enpass app and OS on your device.
  2. After creating a manual backup of your data, try reinstalling the app.
If the issue persists, please share the below details with me -
  1. The version of the Enpass app and OS you are using.
  2. Are you facing this concern for all the Items and all the Sections or any particular ones? If there are specific ones, kindly share them.
