April 22, 20233 yr Hi there, I got the problem with Enpass tray Panel do not show newest item like full Panel (Ctrl+E). I'm using google drive vault, windows 10 and Enpass app got updated.
April 24, 20233 yr Hi @jyuviole Welcome to the Forums. If I have understood your concern correctly, and do correct me in case I'm wrong, you are referring to Enpass Extension when you mention Enpass tray panel and you are unable to view recently added Items on Enpass Extension? If that is correct, I would like to share that the Enpass extension automatically detects login forms in your browser and shows you the matching Items in Enpass that can be used to Autofill the form. If you would like to view all the Items, you can do so by clicking the 'Home' icon and then sorting by 'Created Time'.
May 17, 20233 yr Author Hi @Abhishek Dewan Thanks for your reply, but i already sort by created time but it still not showing newest item in tray panel but the full one. Edited May 17, 20233 yr by jyuviole
May 17, 20233 yr Hi @jyuviole Please share the version of the Enpass app and Enpass Extension you are using and I'll have this further investigated for you.
May 26, 20233 yr Hi @jyuviole Thanks for sharing the screenshot of the Enpass version. It seems that you are using an older version of Enpass. Kindly update your Enpass app to the latest version 6.8.6 and share your findings with me. If the issue persists, do share the Enpass Extension version as well
June 9, 20232 yr Author On 5/26/2023 at 5:49 PM, Abhishek Dewan said: Hi @jyuviole Thanks for sharing the screenshot of the Enpass version. It seems that you are using an older version of Enpass. Kindly update your Enpass app to the latest version 6.8.6 and share your findings with me. If the issue persists, do share the Enpass Extension version as well Hi @Abhishek Dewan I got it now, the one got error is enpass installed from microsoft store. I download directly from your website and now it working good. Linh/Regards
