Add check box for MFA Required for web site?
Hello,
Sorry for my English, but it is possible to add a check box button [x] when MFA is required to connect to the web site with password?
For remember only :P
Bonus : add a little tag/icon on popup menu of minimized icon of windows notification.
Thanks.
Hi @Vini
Enpass’s Password Audit lists all your Items that could be upgraded to app-based 2FA security. From this list, Enpass can help you update those Items to automatically fill in the required one-time codes whenever you log into a 2FA-secured account.
To learn more about how you can use Enpass to check for 2FA supported Items, please refer to this link.
Hi @Abhishek Dewan !
Thanks for reply.
I understand your answer, but it's not enough, I have internal sites in my company that are not known on your reference site.
I'm just asking for a button click to remind me that this site uses MFA.
Then on the nvidia site, there is MFA with google and the information you gave me does not show me this on enpass...
Hi @Vini
The Enpass app also shows the 2FA notification for every 2FA supported Item.
Flag on 2FA supported website item
Could you please share a list of the domains for which Enpass is not showing the 2FA notification? I will then share it with our dedicated team for further checking.
#SI-1756
