June 1, 20233 yr Since Enpass 6, favicons are used based on the first URL-field in a item. There are cases where you have an item containing a URL, say a Software License, where the URL is only used to get a suitable favico. You have another item for the actual login, and the URL's lead to the same domain. Currently, there's no way to prevent the license-item from showing up at the login-page (if you disable autofil in whole, the login-post won't show neither). The fact that inline autofill and legacy autofill uses separate logic is a problem of its own. Make it easier to use favicon without the item being suggested in login-pages. perhaps a checkbox in the post that disables autofill for both inline and legacy autofill. Enpass 6.8.4, Linux.
June 2, 20233 yr Hi @Ivarson I have duly noted your comments and have shared them with our dedicated development team so they may consider this feature request for future Enpass versions. Your patience in the meantime is appreciated. #SI-3370
