June 3, 20233 yr If it is ok which is the best provider that Enpass supports to use ? That works the most fluidly?
June 5, 20233 yr Hi @ng4ever You can use any supported cloud service according to your preference. Moreover, your cloud always contains a copy of same encrypted data as on your device. A copy of your encrypted data is downloaded on your device where is gets decrypted (locally) for real sync operation to merge changes. Afterwards, it gets encrypted again and uploaded back to the cloud. In a nutshell, your cloud works only as a storage medium and no cryptographic operation (encryption or decryption) is performed there. All such operations are performed locally on your device and your data never leaves your device in unencrypted format. To learn more about security with Enpass, please refer to this link.
