July 22, 20233 yr My primary vault will only sync via wi-fi sync, which is a problem for me. I would prefer that my vault syncs via iCloud, but I don't see any option to do that. Is there any way to change the method of syncing for the primary vault?
July 24, 20233 yr Hi @CleosMom To change your cloud service, you will need to disconnect your vault from the Wifi Sync server first. You can do so by going to Enpass app Settings -> Wifi-Sync -> Wifi Sync server -> Stop. Once done, You can set up cloud sync on your device for your vault by going to - Setting’s → Vaults → Select the Vault for which you would like to setup sync → Setup Sync → Select the cloud → Continue.
