September 10, 20233 yr I try to ask for this function. Why can't you put both PIN and fingerprint on Android? Often when the fingerprint sensor cannot identify you well to unlock the database and the attempts of incorrect release are exceeded, the main password is requested, and this is a big problem especially if it is long and complicated. It would be nice if you cannot unlock with the fingerprint sensor a PIN is requested instead of the password. Edited September 10, 20233 yr by xmestessox
September 12, 20233 yr Hi @xmestessox Thank you for sharing your valuable feedback with us. Our development team is already aware of this feature request. As soon as I have more information about this features implementation, I will be sure to update this forum. Thank you for your cooperation and support in the meantime. #SI-1456
July 20, 20242 yr Author Is there any news? My password is long and very complex, if I have to enter the password every time the fingerprint doesn't work it becomes impossible. Therefore, if the use of the fingerprint and PIN together is not allowed, I will be forced to use a simpler password with weaker security.
