September 17, 20233 yr After unplugging the external monitor, sometimes the helper scaling is messed up (se screenshot below). The main window is fine and restarting the enpass helps for the issue, but I'd be nice if I won't have to do that every time. The GUI is non-functional in this state using mouse buttons (either I can't find the right area to click on the item, or it just doesn't register clicks at all), I can blindly navigate it with the keyboard. The GUI also doesn't refresh fully when for example highlighting items or typing search criteria. Note: the screenshot was censored for my privacy. Pixelization is not caused by the issue.
September 18, 20233 yr Hi @GwynBleidD We are aware of this concern and our development team is already working on fixing this bug. Once a patch for this issue is released, I will be sure to notify you on this forum. Your patience in the meantime is appreciated. #SI-3415
