October 2, 20233 yr Hi, I just installed enpass fresh on my Debian 12 machine and started setting it up using Firefox. I clicked on Google Drive, it got opened in Firefox and I selected my account etc. When I clicked on open in the Firefox overlay (to open the enpassauth:// link with the enpass app) nothing happened. Enpass kept on waiting for me to complete the login and return with permission/access. I tried this 3 times. Then I gave up, installed Chromium and it worked on the first try. Please fix the sync setup for Firefox (115.3.0esr) on Debian 12. Thank you!
October 4, 20233 yr Hi @Djfe Thank you for informing the presence of this issue. I have shared it with the concerned team for further investigation. In the meantime, your patience is highly appreciated. #SI-3498
October 10, 20233 yr Hi @Djfe After conducting a comprehensive analysis on our part, we would like to clarify that the issue does not originate from Enpass but rather from Firefox.
October 15, 20233 yr Author That's good to know thank you for looking into it. I'll open a bugreport on Bugzilla then.
October 16, 20233 yr Author Update: If I disconnect my vault and then reconnect again (including authentication etc.) then the enpassauth:// link is opened just fine in Enpass. But if I create a fresh account on Debian 12 and then want to connect to my vault from a fresh enpass profile, then it get's stuck again like I described here. The link doesn't get opened correctly in Enpass. If I copy the (enpassauth:// ) URL via the dev console then Enpass recognizes it in my clipboard and that works. If I drag&drop it into a new Firefox tab (without a clipboard) then it doesn't do anything. (even on reload of that tab)
